CCCUK logo
 Ian Allan Motors
Website Control
Recent threads
New Forum Posts
» C5 standard wheels and one aftermarket multispoke. by L88 on Sun 21 Oct 18 16:13
» Help with newly acquired 72 350 Auto by Grahamred70 on Sun 21 Oct 18 12:17
» CCCUK East Sussex meeting in October by Sea5 on Sat 20 Oct 18 22:21
» C2/C3 rear trailing arms plus other parts by L88 on Sat 20 Oct 18 13:56
» Le Mans 2019 by kentvette on Sat 20 Oct 18 12:48
» 2009 C6 LS3 wing mirrors by 86vetteman on Fri 19 Oct 18 16:13
» A trio of C2 owners. by L88 on Fri 19 Oct 18 14:46
» Silverstone Classic 2019 by curious bystander on Thu 18 Oct 18 20:01
» AC belt by corvetteville on Thu 18 Oct 18 17:55
» Spec lists by kentvette on Thu 18 Oct 18 16:41
» Birdcage repair by johng on Thu 18 Oct 18 12:49
» Strange tacho by kentvette on Thu 18 Oct 18 12:44
» What did you do with your Vette today? by FIVE RED on Thu 18 Oct 18 12:25
» C3 Hooker Side Pipe headers by icandycanvas on Wed 17 Oct 18 16:18
» C3 Side Exhaust Pipes by icandycanvas on Tue 16 Oct 18 20:52
» Wiper actuator on a 69L by Ddave on Tue 16 Oct 18 18:36
» Tips by CaptainK on Tue 16 Oct 18 13:44
» Im interested in a C5 Z06 (this time next year) by Benbay001 on Tue 16 Oct 18 12:55
» Engine cutting out after firing up by Firepit on Tue 16 Oct 18 09:19
» Thinking About Hanging Them Up....... by Norm on Mon 15 Oct 18 15:44
» BBCN Regional meet by Nicetie on Mon 15 Oct 18 12:57
» C5 O2 sensor code?? by roppa440 on Mon 15 Oct 18 08:45
» C2 fibreglassing and prep. by L88 on Sun 14 Oct 18 17:16
» Road Atlanta this weekend. by UkBeancounter on Sun 14 Oct 18 14:29
» New Series of Wheeler Dealers an 02 Z06?? by dex99 on Sun 14 Oct 18 12:02
» Door removal on 79 coupe by Nigelcurry on Sat 13 Oct 18 20:01
» American Day - Museum of Power Essex by Forrest Gump on Sat 13 Oct 18 17:44
» C5 Performance Projects - book by robbiew on Fri 12 Oct 18 21:19
» speed bleeders by Grahamred70 on Fri 12 Oct 18 16:17
» South Central Regional Meeting and Midlands-ish Breakfast Club - October by Daytona Vette on Fri 12 Oct 18 10:44
Heads/cam
Go to page: Previous / 1, 2, 3 / Next
Reply to topic
Author
Message
roscobbc
Thu 16 Aug 18 22:05
Re: Heads/cam
roppa440 wrote (View Post):craigyboy wrote (View Post):
For the best choice of cams I would post on the American Corvette forum
But only if you want 20 different recommendations. LOL
Most people seem to decide on a specific cam (and invariable far too wild for their application) then think to themselves - you can't have too much of a 'good thing' and go for an even wilder cam, wondering why the thing is gutless under 3000 rpm (but sounds good) and with only another couple of thousand revs above that they give themselves a virtually un-drivable car...............Had a buddy running a cam with a 265 degree cam @ .050" inlet in 289 cu in Mustang. He had to drop the rear end to a 3.89 or similar and install a 5 speed to get the thing to even pull away from standstill - in the end he had to install self learning fuel injection to even stand a chance of usability - sounded nice though!
CCCUK Chairman
roppa440
Club Member
Fri 17 Aug 18 08:49
Re: Heads/cam
roscobbc wrote (View Post):roppa440 wrote (View Post):craigyboy wrote (View Post):
People don't realise that everything has to match all the way through the engine and back to the rear wheels and suspension for the car to work as a complete package. Just bolting on parts can take away in some areas to get an improvement in "peak" HP (or torque in reality).
Head flow is critical. More is not better. Heads work best when flowing just enough for the cam and RPM in order to maintain a good air velocity. Then the intake flow has to match. Exhaust flow too. Cam timing effects cylinder pressure. Static compression ratio has to match that. Clutch needs to be stronger. Or a torque converter will need a higher stall speed to stop the idle rpm to pull down low when put in gear and give the correct torque multiplication. The rear gears need to match the engine operating rpm range. Getting the power to the ground often needs suspension modifications.
If it was that easy to make a good car "great" every Tom, Dick and Harry would have a great car.
BlackZeD
Club Member
Fri 17 Aug 18 10:44
Re: Heads/cam
"What kind of power are you running?"
Going by my mods and comparing to those cars with similar cars with
similar mods it should be around 640 at the flywheel.
The heads and cam came from AHP as a proven package that is actually very drivable.
I have driven at 50 mph in 6th at just over 1k rpm and theres no bucking etc.
I think a bigger cam would be problematic with driveability.
roppa440
Club Member
Fri 17 Aug 18 12:46
Re: Heads/cam
BlackZeD wrote (View Post):"What kind of power are you running?"
If the weather holds off for the drag racing, taking place at "Newcastle's Hurricane Raceway" in October, do you and Dave Turnbull not fancy having a race up the airstrip?
That would be cool to see. Thumbs up
Sierra
Regular
Fri 17 Aug 18 19:35
Re: Heads/cam
Very nice. What are your mods? Is it on an ls2?
BlackZeD
Club Member
Fri 17 Aug 18 21:39
Re: Heads/cam
They are on an LS7.
Mods if I can remember,
AHP package 4 heads with powdered metal guides, PSI 1511 springs,
hollow Ferrea exhaust valves, tumble polished OEM intakes, titanium
retainers, milled 0.030" with "street porting".
Hardened pushrods, dont know size, had three different sizes
due to milling.
Gaskets, spark plugs and leads are in the heads fitting package.
The cam is AHPs 116 Cali cam, and comes with all gaskets and
new OEM lifters.
Changed air filter to an AFE stage 2 CAI.
I also previously had an ATI 10% underdrive pulley fitted as mine had
fallen off.
Had a Monster stage 2 clutch waiting to be put in for a while before,
with a new Tick master cylinder and a new OEM slave with a billet
bearing support fitted.
Have a Borla Stinger 11 over axle exhaust and an MGW short shifter
to finish.
Phew.....
Dave.
BlackZeD
Club Member
Fri 17 Aug 18 21:41
Re: Heads/cam
Dave,
Whats this Newcastles Hurricane raceway?
Haven't heard about that one.
Probs dont wanna hand Dave his arse............ Smile
Fraser
Club Member
Sat 18 Aug 18 14:52
Re: Heads/cam
The question now is new heads or have the originals ported and upgraded.
roppa440
Club Member
Sat 18 Aug 18 16:02
Re: Heads/cam
Fraser wrote (View Post):The question now is new heads or have the originals ported and upgraded.
New Heads.
roppa440
Club Member
Sat 18 Aug 18 16:15
Re: Heads/cam
BlackZeD wrote (View Post):Dave,
There is an organisation called "Straighliners" that do 1/4 mile Drag, Drift and Timed Mile events on old airstrips all over the UK.
They are going to start events at what used to be called RAF Ouston which is just to the north of the A69 half way between Newcastle and Corbridge. They did the Fastlane show there a few years ago?
They are going to call it Hurricane Raceway and HOPEFULLY (fingers crossed) we could have regular (ish) Drag Racing there. It was going to start at the end of next month but it has been put back a couple of weeks now to something like the 13th/14th October?
Anyway. I am dead keen on supporting anything they put on there. Only a half hour's drive for me.
Reply to topic
Permissions
