CCCUK logo
 ShipMyCar.co.uk
Website Control
Recent threads
New Forum Posts
» C3 Hooker Side Pipe headers by icandycanvas on Wed 17 Oct 18 16:18
» AC belt by berg944 on Wed 17 Oct 18 15:34
» Birdcage repair by L88 on Wed 17 Oct 18 10:04
» C3 Side Exhaust Pipes by icandycanvas on Tue 16 Oct 18 20:52
» Wiper actuator on a 69L by Ddave on Tue 16 Oct 18 18:36
» What did you do with your Vette today? by Ddave on Tue 16 Oct 18 18:08
» Le Mans 2019 by kentvette on Tue 16 Oct 18 17:55
» Tips by CaptainK on Tue 16 Oct 18 13:44
» Im interested in a C5 Z06 (this time next year) by Benbay001 on Tue 16 Oct 18 12:55
» Engine cutting out after firing up by Firepit on Tue 16 Oct 18 09:19
» A trio of C2 owners. by yenko 1969 on Mon 15 Oct 18 21:38
» Thinking About Hanging Them Up....... by Norm on Mon 15 Oct 18 15:44
» BBCN Regional meet by Nicetie on Mon 15 Oct 18 12:57
» C5 O2 sensor code?? by roppa440 on Mon 15 Oct 18 08:45
» C2 fibreglassing and prep. by L88 on Sun 14 Oct 18 17:16
» Spec lists by Jimbo64 on Sun 14 Oct 18 15:36
» Road Atlanta this weekend. by UkBeancounter on Sun 14 Oct 18 14:29
» New Series of Wheeler Dealers an 02 Z06?? by dex99 on Sun 14 Oct 18 12:02
» Door removal on 79 coupe by Nigelcurry on Sat 13 Oct 18 20:01
» American Day - Museum of Power Essex by Forrest Gump on Sat 13 Oct 18 17:44
» C5 Performance Projects - book by robbiew on Fri 12 Oct 18 21:19
» Help with newly acquired 72 350 Auto by Jimbo64 on Fri 12 Oct 18 18:15
» speed bleeders by Grahamred70 on Fri 12 Oct 18 16:17
» South Central Regional Meeting and Midlands-ish Breakfast Club - October by Daytona Vette on Fri 12 Oct 18 10:44
» Essex Regional meeting by roscobbc on Fri 12 Oct 18 08:36
» 1972 Washer bottle wanted by Vetteheadtony on Thu 11 Oct 18 22:48
» Vette Hire In The U.S. by 86vetteman on Thu 11 Oct 18 20:33
» South Central Mids Supper Club Meet by Daytona Vette on Wed 10 Oct 18 07:29
» CCCUK West Sussex meeting in October by robbiew on Tue 09 Oct 18 19:11
» You Like Shine? I Like Shine....... by Norm on Mon 08 Oct 18 19:21
Euro to US tail lights help
Reply to topic
Author
Message
Sierra
Regular
Thu 13 Sep 18 08:56
Hi guys just wondering if anyone can help please.
My car currently has the euro tail lights but I would like to go the other way and fit some US spec led lights. Iím not too bothered about the amber indicators as I will sort that after.
Does anyone know if I can simply contact the indicator wire to the stop/tail wire and it will flash red when I indicate, or is it going to be overloaded.
Iíd also like to have the tail/stop light active on all 4 lights not 2 as it currently is, would this just be looping the wire from one light to another?
Any help would be greatly appreciated.
5 USA
Club Member
Thu 13 Sep 18 13:49
Re: Euro to US tail lights help
You post is not easy to follow and you haven't said what Vette you're referring to.
Leaving everything else aside, the fundamental problem you will have seems to be,
* When a US car has the brakes applied and an indicator is switched on, the relevant 21w brake lamp lamp flashes on and off and the brake light the other side shows solid red.
* Even if your proposal works at all, your car will show NO rear indicator if the brakes are applied. All the brake lamps will be illuminated solid red and nothing flashing.
The Stingray has landed!
Sierra
Regular
Thu 13 Sep 18 14:22
Sorry the car is a 2007 c6.
How do you think i could get around one side staying solid and the other flashing when indicating?
Would it be a case of changing the bcm to us mode.
5 USA
Club Member
Fri 14 Sep 18 11:34
I'm afraid I can't help with that as the last Vette I messed about with lights for was my C5. So far as I'm aware C6 is completely different, perhaps using digital control (which reduces the weight of the wiring loom).
L88
Club Member
Fri 14 Sep 18 12:21
Thereís a USA spec rear harness on eBay £100 delivered.
Sierra
Regular
Fri 14 Sep 18 13:48
Thanks, Iím not sure if itís a case of using a us harness or not.
Some say use the us harness and change the country setting on the bcm to us also.
Others say itís just a case of running some wires and no need to change the bcm setting.
Iím wondering if I went with my initial thought of connecting indicator to brake/tail light, will the indicator function work over the brake or other way as you mention
Sierra
Regular
Fri 14 Sep 18 14:21
I donít suppose anyone has the tail light wiring diagram for the euro setup?
I canít find one anywhere but plenty of the us wiring
BlackZeD
Club Member
Fri 14 Sep 18 18:35
Theres one in this thread, mentions euros and standard.
https://www.corvetteforum.com/forums/c5-tech/2793068-no-brak...
Dave
Sierra
Regular
Sat 15 Sep 18 20:43
Thanks, Iíll be honest and it really confused me. The wiring diagram is also very confusing to me.
I wondering if the c5 wiring will be the same as c6?
julian marshall
Club Member
Sun 16 Sep 18 11:41
Just had mine converted from US to EU easy way is to have the BCM
reprogrammed. If you need any help get in touch 07793972997.
cheers
Reply to topic
Permissions
