CCCUK logo
 Adrian Flux
Website Control
Recent threads
New Forum Posts
» New Unexpected Owner of this C3!! by Lomaximus on Sat 19 Jan 19 21:55
» CCCUK Website and Forum by kentvette on Sat 19 Jan 19 21:26
» This seems very cheap for a C7 by GCVETTE on Sat 19 Jan 19 15:10
» Drifting your Corvette by Mule on Sat 19 Jan 19 11:23
» What did you do with your Vette today? by Nick B on Sat 19 Jan 19 09:35
» Help with newly acquired 72 350 Auto by Jimbo64 on Fri 18 Jan 19 20:19
Failed oil pump drive
Go to page: Previous / 1, 2, 3 / Next
Reply to topic
Author
Message
Vetteheadtony
Club Member
Sat 22 Sep 18 23:29
Re: Failed oil pump drive
Forrest Gump wrote (View Post):Vetteheadtony wrote (View Post):What do you mean, “This time”!!
Tony, you've got to take into account Ross's failing oil pressure would have meant he was several hundred horsepower down....He wouldn't have wanted to mention that!!!
Always a excuse Andy!
Vetteheadtony
2004 Z06 lemans edition pro charged
613 BHP
Black C6 ZR1 wheels
FECKING FAST!!!
Club Member
Sun 23 Sep 18 09:04
roscobbc wrote (View Post):'Itching' is not the word that first comes to mind Frank..............'Dreading', 'Anxious', 'Hopeful', 'Lucky' are words perhaps more appropriate Scratchchin Readit
Anxiety and Anxiousness is the probability Ross - you never know what you are going to find - perhaps another Spanner? springs to mind Rofl Laughing Laughing
We are all waiting to know what you find the other side of the sump.
Barry - Daytona Vette
roscobbc
Sun 23 Sep 18 11:33
Almost poetic Barry - how does the saying go? "The grass is always greener on the other side of the hill" - in this case the comparison will surely be "The oil will always be more contaminated once its emptied from the sump"
CCCUK Chairman
Club Member
Sun 23 Sep 18 16:11
Yes Ross it is not dross
I am a poet and I didn't know it.
Hurry up and drop the sump a tad
fingers crossed it is not too bad.
L88
Club Member
Sun 23 Sep 18 18:58
Dump the sump.
You've had all afternoon, what's inside?
roscobbc
Sun 23 Sep 18 19:21
Family things to do today - however whilst dinner was being prepared I sneaked 40 minutes in the garage jacking the front end up in the air and sliding a pair of ramps under the front wheels, blocking-up the rear wheels ready for me sliding underneath during the week.
CCCUK Chairman
roscobbc
Sun 30 Sep 18 19:45
Update
This is what was found today. Oil pump was lightly seized. Disassembled the pump and small pieces of metal were present inside and the piece of wire. Logic would say that metal debris from the sheared oil pump drive in the base of the distributor has entered the oil pump and caused it to seize. The other explanation could be that metal particles from something else have entered the oil pump, seizing-it and THAT causing the oil pump drive to shear. The oil pan issue (I think) is unconnected. Simply a crap quality after-market oil pan with poor quality welding causing the windage tray to 'touch' no. 3 con-rod (which shows no sign of damage other that a few minor surface scratches.
Oil Pump
Damage to tooth of oil pump 'gears'
Damage to underside of 'gear' and a piece of wire found
Damage to bottom bearing surface of oil pump
Sheared oil pump drive
'Detached spot welds on one side of windage tray
Damage to windage tray on oil pan - note the wear mark from no 3 con-rod 'tapping' it
CCCUK Chairman
Regional Rep
Sun 30 Sep 18 22:13
Where's the bit of wire come from do you reckon? Oil pick-up mesh?
Blue '75
roscobbc
Sun 30 Sep 18 22:29
Forrest Gump wrote (View Post):Where's the bit of wire come from do you reckon? Oil pick-up mesh? Don't think so Andy - it looks a thicker gauge material than pick-up mesh Scratchchin
CCCUK Chairman
L88
Club Member
Mon 01 Oct 18 15:37
I’m glad that’s all you found. Must be about the cheapest outcome possible. Start peeling off the RTV sealant and order the bits. It should all be back together by next Sunday lunchtime. Thumbs up
Reply to topic
Permissions
