CCCUK logo
 Ian Allan Motors
Website Control
Recent threads
New Forum Posts
» New Unexpected Owner of this C3!! by Lomaximus on Sat 19 Jan 19 21:55
» CCCUK Website and Forum by kentvette on Sat 19 Jan 19 21:26
» This seems very cheap for a C7 by GCVETTE on Sat 19 Jan 19 15:10
» Drifting your Corvette by Mule on Sat 19 Jan 19 11:23
» What did you do with your Vette today? by Nick B on Sat 19 Jan 19 09:35
» Help with newly acquired 72 350 Auto by Jimbo64 on Fri 18 Jan 19 20:19
Go to page: Previous / 1, 2, 3, 4, 5, 6, 7, 8, 9, 10 / Next
Reply to topic
Author
Message
roscobbc
Wed 07 Nov 18 08:00
Re: Help with newly acquired 72 350 Auto
Don't think personally that the Edelbrock carb is the way forward - its their version of the Carter AFB which, arguably was one of the best performance carbs of its day - but now doesn't seem so good in its present form. You'll need to change the inlet manifold - so why not consider a higher spec' Holly (or generic equivalent) vac secondary - infinately and easily tuneable.
CCCUK Chairman
Club Member
Wed 07 Nov 18 09:42
James, I'm not going to pretend to be an expert on carburettors, but I have had to do a bit or work on my Rochester and found that the Haynes Manual wasn't accurate enough for my '78. I bought this book:
https://www.amazon.com/Rochester-Carburetors-Revised-Doug-Ro...
Much more detailed with masses of info on set-up, etc. It may be worth getting a copy before going down the replacement car route. (You'll find that Doug Roe is a huge fan of Rochesters and reckons that, properly set up, they are the best option! Very Happy )
Stephen J Irons
CCCUK Lifetime Member
Corvette Club France
NCM Family Member
Stephen & June's Web Site
Red Corvettes Have More Fun!
Apple IS Genisys!
Vetteheadtony
Club Member
Wed 07 Nov 18 10:01
Be honest, just take the choke off, not really needed especially if you donít drive a lot in winter, just means you have to sit there and tickle the throttle for a couple of seconds, I find the early Qjet choke more problematic than good!
Vetteheadtony
2004 Z06 lemans edition pro charged
613 BHP
Black C6 ZR1 wheels
FECKING FAST!!!
Vetteheadtony
Club Member
Wed 07 Nov 18 10:08
The other option is to knock the lock pin on the secondary flap shaft through a bit with a punch so the choke mechanism donít touch and lock it, itís only like a Clevis pin and only needs to be pushed over about 5mm.
Vetteheadtony
613 BHP
Black C6 ZR1 wheels
FECKING FAST!!!
Vetteheadtony
Club Member
Wed 07 Nov 18 12:01
Another option
https://www.summitracing.com/parts/edl-1906
Never a problem again!
Vetteheadtony
613 BHP
Black C6 ZR1 wheels
FECKING FAST!!!
Jimbo64
Club Member
Wed 07 Nov 18 16:52
Scott;
Received the 5amp fuse in post today, many thanks.
Must admit, do like the look of the AVS series and I'm just wanting something that will work !!
Happy to be Grumpy
Jimbo64
Club Member
Thu 22 Nov 18 12:21
Making progress with my 72:
Rear window resealed and not leaking.Water now runs correctly into channel below window and into new rubber pipes and out above each wheel.
New lap seatbelts, electric window console, wood veneer on centre console, various bulbs & fuses all fitted/replaced.
Engine bay cleaned and tidied up, new oil, filter, plugs all fitted.
Just awaiting new carb, adaptor plate & fuel line kit, to get her running.
Happy to be Grumpy
Jimbo64
Club Member
Thu 22 Nov 18 12:23
Interior looking quite good, well I'm happy!
Happy to be Grumpy
Jimbo64
Club Member
Thu 22 Nov 18 12:36
Engine bay after further cleaning
Happy to be Grumpy
Nick B
Club Member
Thu 22 Nov 18 13:10
Nice progress Jim, looking good!
Reply to topic
Permissions
