CCCUK logo
 Lancaster Insurance
Website Control
Recent threads
New Forum Posts
» What did you do with your Vette today? by Vetteheadtony on Tue 22 Jan 19 11:39
» New Unexpected Owner of this C3!! by L88 on Tue 22 Jan 19 10:59
» Power Windows by roscobbc on Mon 21 Jan 19 20:50
» CCCUK Website and Forum by roscobbc on Mon 21 Jan 19 20:47
» C6 Z06 Flat battery by Tattooboy on Mon 21 Jan 19 20:03
» This seems very cheap for a C7 by roscobbc on Mon 21 Jan 19 17:28
Birdcage repair
Go to page: 1, 2 / Next
Reply to topic
Author
Message
Club Member
Tue 16 Oct 18 14:19
Birdcage repair
Does anyone have any experience, tips or advice regarding birdcage repairs? Specifically, in relation to replacement of the windscreen lower outer panel. That's this one.
Most people seem to remove the front clip to do this, but I really don't want to extend my restoration time any further, so I'm going to try the method that Corvette Kingdom show on their website. I've ordered a panel from them and Scott was very helpful in explaining how they do it, but I'd appreciate any other help I can get before the panel arrives.
If you're not familiar with the method, it involves removing the inner panel to get access to the outer panel, then remove that and replace them both. Sounds easy if you say it quickly!
Here's how my car looks with both panels in place, then only the outer and now neither.
Hopefully I've worked out how to add photos properly.
John
roscobbc
Tue 16 Oct 18 17:22
Re: Birdcage repair
Nice to see you are getting on with it - ready.in time for Essex regional meeting tomorrow night?
CCCUK Chairman
Club Member
Tue 16 Oct 18 19:12
Re: Birdcage repair
Yes almost. Are you going to bring along your sheared oil pump drive?
roscobbc
Tue 16 Oct 18 19:25
Re: Birdcage repair
most definitely!
CCCUK Chairman
L88
Club Member
Tue 16 Oct 18 19:54
Re: Birdcage repair
Good to see someone else is getting in deep. You might as well carry on with Scottís instruction. Mine have front ends off, itís best to clear as much room for welding, Iím just about to order an upper screen frame I presume you are going for inner outer lower frame?
Club Member
Tue 16 Oct 18 20:33
Re: Birdcage repair
I'm just replacing the lower outer, the inner panel is fine so I'll re-use that. The bit I'm most concerned about is the welding as access is pretty restricted and has to be done from the inside of the car, plus of course I need to be careful not to burn the firewall. Do you only have problems with the upper frame, or with the lower as well?
L88
Club Member
Tue 16 Oct 18 21:10
Re: Birdcage repair
I have problems where you really shouldn't have problems! The pictures tell the story of the upper frame, one side of the lower is perfect the other not so perfect but it's all good fun.
IMG-2514
IMG-2518
IMG-2520
Club Member
Tue 16 Oct 18 21:19
Re: Birdcage repair
Wow, the state of your upper frame makes my corrosion seem less worrying now, although at least you can get at things easily enough. Strangely, I have corrosion at the bottom left hand corner and a small bit at the upper right hand corner, but not in the other 2 corners.
L88
Club Member
Tue 16 Oct 18 21:42
Re: Birdcage repair
It's only metal and the upper frame comes with inner/outer spot welded together so won't take long. If you have rot on either left or right sides of frame I have a pair cut from a C3. Have you already bought a repair piece ? I know of a complete inner and outer lower screen frame for sale.
Club Member
Wed 17 Oct 18 07:25
Re: Birdcage repair
Afraid I've already ordered an outer panel from Corvette Kingdom, not cheap but it seemed fair as I wanted their advice about fitting it. My sides are both okay, but thanks for the offer. I do have a long list of other bits that I'm going to need if you know someone who is splitting a car.
Reply to topic
Permissions
