CCCUK logo
 Ian Allan Motors
Website Control
Recent threads
New Forum Posts
» 2020 Corvette C8 by curious bystander on Fri 18 Jan 19 17:55
» Help with newly acquired 72 350 Auto by Nick B on Fri 18 Jan 19 17:04
» Wanted: C5 front wheels, set of 4... by robbiew on Fri 18 Jan 19 13:59
» What did you do with your Vette today? by kentvette on Wed 16 Jan 19 15:52
» Drifting your Corvette by Fishy Dave on Wed 16 Jan 19 11:34
» Earls Barton Classic car and bike Meet by Nicetie on Fri 11 Jan 19 15:43
» Sywell Pistons & Props by Nicetie on Fri 11 Jan 19 15:42
» Kop Hill Hillclimb by Nicetie on Fri 11 Jan 19 15:41
» AACI Open Nationals at Billing Aquadrome by Nicetie on Fri 11 Jan 19 15:40
360, 383 or 440 - which is best for the beast?
Reply to topic
Author
Message
Paronaold
Lurker
Thu 10 Jan 19 13:12
This is someting I often ask myself, having owned an FF (with an E-series , high compression 383) and now an Interceptor (with a J series "woofly" 440).
I had looked at fitting a 484 into my FF https://bestarny.com/%D1%81arburetors-for-383-stroker/ (a 383 block with a 440 crank I believe) but got concerned about the fuel consumption..
Very interested in all your views....
roscobbc
Thu 10 Jan 19 18:18
Re: 360, 383 or 440 - which is best for the beast?
Paronaold wrote (View Post):This is someting I often ask myself, having owned an FF (with an E-series , high compression 383) and now an Interceptor (with a J series "woofly" 440).
I had looked at fitting a 484 into my FF (a 383 block with a 440 crank I believe) but got concerned about the fuel consumption..
Kinda think you've come to the wrong place - the clue is that this is CCCUK (Classic Corvette Club) and not a Mopar forum...................
When I had a 489 stroker big block Chevy built for my Vette - at the time when dyno'd it had the second highest torque figure for a NA engine (606 ff/lbs) - the highest? a NA 496 stroker Mopar engine - beat mine my 30 ft/lbs or so Yes
CCCUK Chairman
Redlevel
Club Member
Thu 10 Jan 19 18:40
Hi..
We totally have a resident Mopar fiend on board here.. I'm sure he'll be along the noo..
Cheers,
Steve..
roppa440
Club Member
Thu 10 Jan 19 21:47
The 440 is a physically big engine for the interceptor which is why they tend to run quite hot. It's just a bloody tight fit.
If I was you I would use a 400 block and 440 crank. Something l8ke 451 inches from memory. Physically smaller and lighter than the 440. Larger standard bore than either the 383 or 440.
People like 440 Source in the USA sell good priced kits. You also have the option of a stroker crank in the 400 making it 500 inch.
The flat tappet street/strip 440 I built for my Challenger put out about 530hp at the crank and on a run I could get as much as 13 MPG on the motorway.
My mate has built a street/strip 500 inch 400 with a roller tappet cam and that dynoed at 626hp at the crank. I doubt it will get double figures on the MPG front.
Reply to topic
Permissions
