Rear muffler query.
TimP
I always find it strange to see a mix of decimal and imperial but it did remind me of a new trainee air conditioning engineer I trained. I asked him to measure a wall to find the centre so we could hang a wall mounted unit. He came back and said 8 mtrs, 7 foot and 4 inches. That was probably near 40 years ago and he's still with us and one of the best engineers out there.
Similarly it's a bit odd that we buy tyres that are imperial in diameter and metric in width.
I was still at primary school when the UK started preparation for metrication in 1971 (I think). We learned both metric and imperial measures for about three years prior to this but recited all measurements, volume (gills, quarts) and linear (chains, furlongs etc), twice a day every day from aged 6 to 11. I can still recite them now. I think this is the main reason I tend to think of any dimension less than a foot in metric and anything greater in imperial.
Decimalisation was a significant cause and effect of decimaliation back 'in the day'. Effect, because businesses, both large and small, shops, in fact anything you would purchase became victims of 'rounding-up', where the 'imperial' price was converted to 'decimal' and then rounded-up (never, ever 'rounded down). So, for example an item in old money costing, say £1/12s/6d (so 1 pound - 12 shillings and 6 'old' pence) would directly converted to £1-62 -1/2 'new' pence in the decimal money. It was such an easy move for the traders, retailers etc to 'round off' up to £1-70p, £1-75p, perhaps even £1-80p........and so rampant inflation started......
Don`t forget poles and perches too .
Air condioning pipes are 1/4 3/8 1/2 5/8 3/4 7/8 1 1/8 1 3/8 1 5/8 2 1/8 etc but the insulation is 6mm 9mm 12mm 15mm 19mm etc..
Seems to be several mixed combos and yes the tyres is a prime example.
A pint will always be a pint though 🍺
Odd really that totally metric sized tyres historically have 'flopped' - thinking about the 190/65R390 as fiitted to some Mk 2 Granada's, 230/55/ZR390 fitted to some BMW's
John lee
New user
When I first got my C3 20 years+ ago the very first thing I simply had to do was A. buy a pair of headers B. buy a pair of mufflers.
As you have already noted Cherry Bombs sound too strident. TBH, I had always done this with every car I've every owned, from old school Mini Cooper glass packs on 3.8 Jags to Thrush turn-o-lock glass packs and header mufflers on Yank V8's. (Viagra, Cialis levitra pas cher)
I had used Simon's mufflers - made for years in Denmark or somewhere similar and marketed here in the UK as Jetex - Available in polished stainless or satin black mild steel they are an absorbsion tube muffler but always used ceramic wool rather than glass fibre which wouldn't oil or coke-up and end-up getting really unpleasantly noisy. I had mine on the Vette for at least 10 years with no corrosion......they did get a little louder after a time.
If you want to replace your existing mufflers on a visually like of like basis simply search for the correct tube diameter and case length approximately the same as your existing mufflers (perhaps even a little longer if you want) and get your favourite exhaust shop to make-up the required brackets and tube bends to fit them.
Bonus is they will look stock, even sound a little 'softer' on idle than stock but progessively get louder as you hit the gas pedal.......never loud enough to attrack the old bill, but in a really nice way without the drone of some baffled mufflers. Remember that a larger (even oversized) diameter pipe will always sound deeper.
If you need to replace the entire system, opting for a 2" to 2.5" system is an excellent choice.
