Vetman
Cooler intake air makes more power due to higher density and more oxygen to boost the bang. The 73 to 75 C3 cars used a hood cowl induction system to access cooler air but the system was compromised by underhood intakes and a flap to block external air except at wide open throttle, WOT. The flap often fails to open over time due to solenoid failure or poor adjustment of the throttle peddle switch. I removed my cowl flap, rubber seal and solenoid some years ago to let more cold air in or hot air out. My car no longer had the original air cleaner and rubber seal to the underside of the hood and instead had a 14” round chrome air cleaner. This looks good but draws in hot air from the engine bay.
I have now made my own intake surround based on an Edelbrock 1002 air cleaner as shown in the attached photo. I wanted to keep the bling but also to use the cowl system without pulling in any hot air from the radiator and engine. This is working well and measurements of intake air temperature compared to surrounding temperature indicate a 20 deg C reduction during fast runs. This equates to about a 4% power increase and a great sound. This difference may increase for summer temperatures and headers.
Any comments?
Any comments?
