1998 Auto Radiator
VantaR
Busy user
Hi everyone,
Just a quick one, although unfortunately i've got a bunch more questions coming :)
i'm getting a HIGH TRANS TEMP and LOW COOLANT warning on my 98 euro auto. Monitoring trans temps they seem to be fairly normal even when the warning comes up, and engine temps seem fairly normal too. Coolant level also normal (so figure it's a combination of a bad sensor and radiator) Steve has been very helpful and I think i need to start replacing things. Looks like my radiator is bent! Image Attached
So best to start there? What's the part number for a replacement radiator with the internal trans cooler? Ideally on rock auto if possible, I've seen two one with inverted flares (and after a quick google I still couldn't figure out the difference) I know the better solution is to run an external trans cooler, but I'm just trying to sort out all issues first and when cashflow allows I'll consider :) I dont track the car.
Thanks in advance!
