Thanks all, looked at these products and yes they will work but as you say theye require a special (expensive) gun.
The main problem from my point of view is that you still have to mix the two parts by hand, to me this renders the gun of no help apart from measuring out an equal mix (or am I wrong?).
What I have found is a company in the UK that produce many epoxy resins, having contacted them they have a product that will bond Polyester GRP to itself and to most metals it is thixotropic and suitable for use on vertical surfaces they do a 'slow' version with an open time of an hour, the company also supplies empty cartridges (they fit standard cheap from the market gun) that can be filled once the two parts are mixed together they also do long injection nozzles for reaching deep inside assemblies.
At this point I was thinking this is too good to be true that is why I have not mentioned their name............... I will do a post once it all arrives and I have had a go.
Glyn
