C8 pricing available
c6_pete
I'd imagine that the £5k Z51 pack will be standard on UK/Euro cars? Including:
Michelin® PS4 Performance 3 Season tires, Standard FE3 Performance Suspension, Available FE4 Suspension with Magnetic Ride Control™, Larger 345 mm front and 350 mm rear brake rotors, Extra cooling with additional rear-mounted third radiator, Electronic Limited-Slip Differential, Larger rear spoiler provides up to 400 lbs. of downforce, Performance exhaust results in 495 HP.
z06_tim
Busy user
Almost certainly. And probably the 2LT package, or most of it too. What does that make a UK car? Nearly $75k, which probably translates to £75k by the time it is here. Or more depending on how low the GBP drops against the USD by the time we can get one over here!
N
Norm
Guest
Well.......the rumor was the new C8 would come in under $60K.....and it did, and of course you know the buts............:eek:
