Vetman
I took my 75 L48 modified for a run yesterday and on returning home I noticed some tappet noise on the passenger bank. Today I removed the valve covers and spark plugs in order to adjust all the tappets. I turned the motor on the crankshaft pulley nut by spanner to each cylinder TDC based on firing order at 90deg apart. I found zero lash and added a 1/2 turn tightening to the adjustment nut. I used the starter motor to spin the engine and all ok. I replaced the spark plugs and leads and fired the engine. Very noisy and worrying, and a burning smell on the passenger side, so I switched off. I removed the passenger cover and checked the rockers and all seemed fine. I fired the engine again and the engine was quieter. I used a length of wood as a stethoscope to listen for unnatural noises but seemed ok. I switched off, replaced the cover, and removed the driver side cover to check and listen to this side. Starter motor dead. I connected the battery charger and tried again but still dead. Ho hum.
Any thoughts.
Any thoughts.
