A grand day out Grommet !
I switched it on as soon as you went indoorsWhere did the Sunshine come from?.. i must have been inside.
Does anyone know why a MOV video file would constantly keep stopping and starting making it jerky?.. new camera, first time ive used video. It does say recorded at 30 frames per second so it shouldnt be all Laurel and Hardy.![]()
Huge Thank You Dave for sorting me out with a pair of your finest stockings and the required equipment and assistance to put them on...
oh.. and for the hosepipe.. hope your wife didnt mind.. they got me home without further incidentand Great to meet you.
Thank You also to Barry for organising a great day.
You very lucky to get away with overheating issue on the M40 caused by the water pump / fan / alternator drive belt snapping and getting chewed up in the innerds ! Does your battery charge warning light not work to signify a problem of no charge from the alternator ? Hope the overheating hasn`t caused problems elsewhere in the block or cooling stystem .Ideally 100 denier but you cant always afford to be choosy, you have to make do with whats on offer.
You need to get those warning light issues sorted PDQ and learn a bit more about your otherwise you will never know whats going wrong until it`s too late . Is your car a manual or auto ? Coasting on a motoway is a bit dodgy in my opinion . Was the engine still running ? As you had no fan belt left intact you wouldn`t get the cooling effect from the fan anyway .Good point.. i didnt notice a light.. just been out to check.. no, i dont have a working ignition light/ battery charge warning light and the voltmeter doesnt read correctly.
Had to pull onto the hard shoulder four or five times to let it cool down, once on a long downhill so switched engine off & dropped it into neutral and let it roll.
Its running fine, no problems. Gave it a good testing nearing home and its not suffered any performance drop.
Clearly Chevrolet thought it was worth while fitting charge lights to later C3`s . It would tell you your alternator was not charging due to your drive belt having snapped . That seems a pretty big deal to me ! With your battery firing 8 cylinders and powering your electric fan which was the only cooling you had , I am amazed you got off the motorway and made it to Gaydon .Im in the habit of frequently scanning the Oil Temp, Oil pressure, Water temp & my dodgy slightly low reading volts meters which is why i spotted it was getting hot straight away.
I was coasting on the hard shoulder with engine off in neutral.. yes im aware you lose power assistance on the brakes & steering.
The 1981 has two cooling fans as standard... one electric and one engine driven.
As the 'ignition light query' thread shows, earlier C3's didnt even have a charge warning light so its no big deal that mines not working.
Seems to be my laptop is causing the problem, downloaded to my old PC and problem solved...Does anyone know why a MOV video file would constantly keep stopping and starting making it jerky?.. new camera, first time ive used video. It does say recorded at 30 frames per second so it shouldnt be all Laurel and Hardy.![]()
