Hi , anyone use a cloth or other material dashboard pad or cover to get rid of the shiny dash reflection in the windscreen glass? TiA
That does the job but was looking for one that just stays in place without glue or fixings , if such a thing is available. I may try the grippy perforated sheet and cut to shape.Bought the fake Alcantara off eBay, glued down over the existing dash pad.
They’re called dash mats. You see them in loads of the hotter States. Sure someone does a C3 one.That does the job but was looking for one that just stays in place without glue or fixings , if such a thing is available. I may try the grippy perforated sheet and cut to shape.
I have seen a dash mat on a C3 , maybe someone on forum has one fitted . Fortunately I don`t really get bothered by reflection as a previous owner fitted the dash top and facia with faux leather seam stitched material . The shiny plastic speaker grills cause a bit of reflection though if sun is at the right angle .They’re called dash mats. You see them in loads of the hotter States. Sure someone does a C3 one.
What a great name !i will have a google aroundThey’re called dash mats. You see them in loads of the hotter States. Sure someone does a C3 one.
Thanks CaptainK , the tiny switch is the spring loaded horn switch would you believe ?? Who ever installed the Grant GT steering wheel did not install a horn push in the centre boss !! It felt odd at first but soon got used to it .Chuffer - that is a great interior inside your car - looks really nice.
Out of interest, what is the tiny switch between the two electric window switches on the centre console? Passenger ejector switch?
