Corvetteville
Acronyms ehh?
OK, my EGR is connected to the top port of the TVS on the manifold, but the vacuum hose from the lower port goes to the upper port of the EFE TVS & not to the carb??. I have tested the EGR & TVS with vac pump & they work & hold vacuum ( TVS cold & closed)
Has this been done to improve performance?
Also, I can't find an EFE actuator or hoses to & from the stat housing TVS??
So in effect they're both non operational & the fuel cannister as well?
Car seems to run fine, ( slightly reluctant starting from cold) auto choke works. Needs a few pumps, which works, also have the heat riser built into the air pan snorkel, which is connected & seems ok on vac test.
Please let me know what you think, should I leave alone? Thanks in advance, ( pun, LOL
).Steve
