Flasher location 72
Nothing to remove. Once you know where to find it, it's an easy reach up under the lower passenger dash pad.
It should be held in a metal spring clip - you just snap it out and disconnect the wiring. Some PO had been messing around on mine and the flasher unit was just suspended on the wiring.
I was getting a little woried here fella's in case someone mentioned "there is a 'Flasher' behind the steering wheel"!
Thanks for that, the hazards work fine so all the bulbs and wiring /earths seem good so hopefully just the flasher, hopefully here today. I had been out three days in a row since stopping the gearbox leak , so nice not to be limited distance wise and to keep checking and topping up gbox after every little run. . Then no indicators so grounded again 😤🤣👍
TimP
Just as an aside: the 4-way hazard flashers use a small indicator/flasher unit that is mounted on the fuse panel just above the pedals.
Thanks tim, I was wondering where the other flasher was, the hazards are all working fine btw.
Talking about the pedal area , you have probably had a good look at the pedal shaft , can I get some grease on my clutch pedal shaft from the footwell to see if that is the source of my noisy pedal, a grease nipple posibly up there ?
Turn signals all working at correct speed now . The old flasher was obviously on the blink (see what I did there)🤣 ever since I got the car ! Thanks guys for all yr help and to Gavin Roe For getting one down pronto 👍
TimP
Hi Gary, There isn't a grease nipple as such but it shouldn't be too difficult to get some grease on to the clutch pedal 'axle' where it hinges on the bracket - particularly if you have a white lithium type spray grease with the drinking straw attachment on it where you can direct the jet quite accurately. There is a also a cut out in the pedal bracket which would help with that - see pic.
There is a also a cut out in the pedal which would help with that - see pic.
I got somev spray lithium grease up and around the area A lot of bits in the way so hope it got in there, I will go and look at the pedal bracket hole and have another skirt . Will call you Monday re tuesday meet. 👍
TimP
Something I found out the hard way this week: the direction signals will not work properly if the hazard flasher unit on the fuse box is not present. I had convinced myself sub consciously that if there are separate flasher relays then they must be independent - not true.....
