Ground connections
Milanm10
I have a issue with my 08 c6 in that sometimes doors won't unlock and open and engine won't crank. I think it might be a bad ground can anyone please help In telling me where the main ground connections are I am thinking might be the ones under the battery tray but not sure.
First check for common problem as there was a batch of battery cables for the C6 where the battery terminal connectors
were not crimped to wire correctly.
Wiggle test both and see if any changes and assure the posts of battery are clean
Check negative cable end to frame is clean and tight connection
Check main engine ground, not recall on C6s but C5s there is a flat braided ground wire bolts to backside of left head and other
end to frame, check both ends.
