Richard
Balancer cost is about $250 US plus, depending on if wanting a stock one or a racer type
Also, should change the serpentine belt and check that the idler pulley or bearing did not get damaged
Just an idea on pulley parts
Balancer and Bolt
Check local to you on costs
You MUST replace the bolt as it is a
one time torque to yield design,
If you mess up putting the new one on, it is stretched and is then trash and need another new one
Power steering pump has to be taken off engine block
Have to loosen up and move the steering rack out of the way, along with brake lines on driver's side
Need the engine locked down to assure when torquing to spec the new bolt that engine does not turn causing
incorrect torque setting
If needed, find a way to lock the engine down with a tool vendor's sell
I made mine shown below, it replaces the starter to lock flywheel or [ flex plate (tool is different) ]
If not wanting that bolt to get loose in the future, vendors sell a tool like I have below that allows you to bolt
a jig up and then drill bit drills a hole on the edge of the center of pulley and crank for a key pushed in
to lock pulley to end of crank
Review this forum thread when I installed an EVS supercharger on a C6 as it has photos that show crank pulley bolt, etc
Installing EVS SC'er
Some photos further down that page or
click on "Install EVS" to see more photos in a slideshow
