Hi, just a little story really. When I changed my rocker covers, I removed the blank and installed a breather on the left cover, and swapped the pcv valve on the right cover for a fancy looking one. Hadn’t really driven the car since, and with the weather like it’s been have put a few miles on the 74. All this was based on online opinion that a breather, not a blank should be fitted.
On initial start up Saturday morning, it was massively over fueling, I put this down to being sat for a while, and it cleared after warming up. But, the idle wasn’t right, but drove ok.
Sunday morning, same thing, so I figured something was up. After a bit of research, I found conflicting opinions on breathers and blanks. I pulled the pcv valve off, tested it, and it was open all the time. So i refitted the old pcv and blank, and hey presto, cars running perfect again.
For aesthetics I’ve blanked the breather I bought, and put a new pcv in the other fancy case.
Moral of the story, just because you can, doesn’t mean you should!
Tim.
Tim.
