LT1 Pistons / Rods in a L48 Engine
8DJA
Hi Guys,
Quick question, I spun a crank bearing which in turn damaged the crank and one of the connecting rods.
I have has the crank repaired and found some used Pistons with rods on ebay, however I have just realised they are for an LT1 Chevy 350 engine and i have a 1976 C3 with an L48 engine.
My question is, will these still work ok in my engine?
They look to be the same size as the originals but wanted to check with you guys before I installed them.
Thanks for your help.
