Mini Hi-Torque starter motor for C3 81
I have found some have the electrical connections in different places and by chance my last one had the connections situated further from the exhaust manifold - every little helps - whilst you are there a heat shield is a good idea, but not a heat shield blanket
Stateside Autoparts - Atherstone
Real Steel - Cowley
I fitted a high torque gear reduction starter on my 1980 C3 but ended up getting it from Ecklers USA . A straight forward fitting job to get correct gear mesh and lash with fly wheel ring plus no need for diode in the wiring harness as 1974 onwards don`t have ballast resistor or a points type distributor . Cost about £170 I seem to recall . A big improvement on the original `half ton` job and more air space around it as Daytona said . I also wrapped exhaust in that area for greater protection against heat soak too.
RobsVette
Thanks
Dellb
I got mine from real steel. Lifted in with one hand, tightened the bolts with the other.
One point however, there is no R terminal, so you will need a diode if your setup requires it.
Dellb
Oh. Don’t wish to teach a granny to suck eggs, but don’t forget to specify if your block has offset starter bolts.
Is that to compensate for the ballast resistor bypass on start up?
Which one did you go for Real Steel list a couple?
Dellb
Yep
It is to compensate for he bypass on the ballast resistor.
I,ll send details tomorrow when I crawl underneath. One other point, is the fact that the one I got can be set at a number of different positions which really helps getting it clear of the header.
Dellb
I Went for the BY9112. But don’t forget I have the offset bolt pattern. Interestingly, I got the diode kit from Amazon.
