Finally found the problem in my 1968 C3 - and its quite an obvious one when you think of it. For years now, ever since I've had my C3 to be honest, its never really been that quick, and never seemed to want to rev over 4k..... and getting there was a push as it was quick to 3.5k rpm, then slowly increase from there until it topped out around 4k.
When I first got the car, it had other driving issues, stalling, general not happy around town etc. Got a garage to swap out the carb (a fake chinesium Carter) and distributor for an Edelbrock 1406 and a HEI distributor for me. This solved all my problems except the revving above 4k issue.
Now, I'm not one for driving my C3 hard, I like to just cruise in it, and to be honest for a while I'd forget about its 4k issue. So I'd only really remember about it here and there over the years, and it wasn't a priority for me compared to other minor issues. Tried a few other things over the years - heat reduction, vacuum leaks, blah blah blah. Just resided myself to it not being that quick as it didn't bother me much and it'd be solved if and when I decided to do a 383 engine stroker like Andy's car as the engine builder would look at it etc.
Fast forward a bit more and I was in the engine bay last week checking levels and stuff and decided to take the air cleaner off to check inside that etc as not done that in years. It was then my brain had a lightbulb moment and thought something looked odd about the throttle cable. So I checked it, and it was all tense and seemed fine. But my brain wasn't happy, so I played with the throttle manually by hand at the carb, opening and closing it. All seemed fine. Then for some reason I decided to check it from the throttle pedal in the car, and noticed that the throttle was only opening around 1/2 - 2/3's from the pedal !!!
So in a nutshell, it turns out my throttle cable bracket on my carb is a bit odd and only held on with one bolt. It had slipped, and thus reduced the maximum throttle opening. I repositioned it, and tightened it up, but it slipped back immediately on first let off of throttle.
Anyway, fabricated a bracket extension to bolt to it that then forms an "L" shape around the base of the carb by the throttle bracket. This is tight and stops it slipping. I now have max throttle opening via the pedal. Took it for a test drive and fudge me when you put your foot right down it is a LOT quicker now and shoots up to 5k rpm with ease. I'm mechanically "huh?" with carbs, but I'm guessing before that with the limited throttle opening before that the secondaries weren't opening or whatever.
If anyone has a photo of what a proper SBC throttle bracket looks like on a C3, that'd be fab. I did Google and go on CK and other Corvette parts suppliers, but the brackets vary over the years and none of them look like what I have. I have a 1968 SBC too, so that probably doesn't help.
