Hi all , I have a new park brake lever to fit as I broke the plastic grip. I am using the original ratchet, can I drift out the roll pin/, in situ or do i need to remove ratchet from car and fit new lever on the bench ? Also I cant see that the sliding seal in the console has a split to enable it to be eased around the park brake lever, do I need to cut with a stanley blade or is it somehow clipped together? Many thanks in advance, a good point is After adjusting the park brake shoes at the rear wheels , I now have a pretty good park brake that holds properly .
