C5Steve
Bit of a weird one, I've done a lot of searching and can't quite find the issue I'm having.
So, a few days ago when unlocking the car, I noticed the rear marker lights did not come on with the front lights (UK market sidelights, the little spot lights at the front). The reverse lights come on at the rear, but no rear marker or rear running lights. This has become more and more intermittent to the point where now they won't come on more often than not.
Symptoms are:
When unlocking OR turning the lights on, the rear side markers, rear running lights and rear number plate lights don't immediately come on.
They will sometimes come on after a minute or so by themselves, I've seen them flicker slightly at times as well before coming on.
All other lights work as they should, including brake lights, indicators and reverse lights at all times.
The car does have front and rear LED (Radioflyer) lights and LED side markers. These have been installed for years with no issues, all other aspects of the lights are fine except the running lights and side markers.
I know the basics to check, ground points and connectors but it seems very odd it's just the number plate lights, running lights and rear side markers. I would have thought if it was a grounding issue it would be all the lights? Also, the multifunction switch is about two years old or so as I replaced this.
Any pointers on where to start?
Symptoms are:
