R134a air con conversion
Dellb
Hi All
This post is leaving me somewhat embarrassed. After spending over 4 years rebuilding my 1980 C3, I have come across a problem that has me stumped. I have renewed every component on the air con system, and it will be soon be ready for charging. My problem relates to the hose assembly that bolts direct to the back of the compressor. I have a pack that contains two aluminium spacers, a red and green joint ring which look like oversized dowty seals and normal green O rings.
What goes where.
Also, it looks to me that once the hose is on, it will be too close to the compressor rear bracket to get a charging connection on.
Has anyone had these problems?
Delb
