Rear bush query.
Hi all, I have some side to side slack in my output shaft bush . Can any folk tell me if this could cause a drivetrain clunk when changing gear? I cant see any movement in the diff cushion rubbers, or slack in any propshaft or driveshaft u/j’s. 🤔 TiA 👍
I know mine has some side to side movement too, but there’s no clunking that I’m aware of.
It leaks a bit of oil as a result of the movement though and has probably got wear on the seal.
Have you checked the front diff cushions
Thanks gavin, I did when you sent me down a new set but only from the floor so didnt get a bar in there. Will have a better look. Is there a correct place to lever and where to look for movement. I sort of presumed they should have still been good from the rebuild 8years ago but I guess they could go bad again in this time ?
