See the C8 Z06 Reveal tomorrow Tues, 12 PM ET USA
Set your schedule to see this !
The worldwide reveal of the all-new 2023 Chevrolet Corvette Z06 will be shown on Oct. 26 at 12 p.m. EDT.
The feature film will be followed by a panel discussion featuring a variety of individuals who will bring a unique perspective to this new supercar that will put the world on notice.
Viewers may tune in at C8 ZO6 Reveal
Found the answer, 460 ft/lbs Torque, that is the maximum the DCT has been able to handle :(
America’s newest supercar is powered by Chevy’s revolutionary LT6, a dual overhead cam 5.5-liter V8 which makes 670 horsepower and 460 lb-ft of torque at 6300 RPM.
As racing and performance enthusiasts love naturally aspirated engines for their responsiveness and trackability, the small-block LT6 was a clean-sheet design with the goal to create a naturally aspirated power plant that would exceed the power of any naturally aspirated production V8 engine ever made.
To accomplish that goal, Chevy engineers turned to a flat-plane crankshaft design, which combined with the LT6’s short stroke enables the engine to redline at 8,600 RPM.
The LT6 also features forged aluminum pistons and forged titanium connecting rods for low mass and high strength, and a six-stage dry-sump oiling system.
It also looks like no other Corvette engine before, with an all-new active split-intake manifold with 87 mm throttle bodies and distinctive camshaft covers.
Chevy’s mid-engine Corvette revolution continues with today’s official reveal of the 2023 Corvette Z06, a precision tool for the track as it is being described. Its body is wider and longer, it’s more powerful than expected, and did we mention that sound from the 5.5L flat-plane crank V8?
“The new Corvette Z06 defines the American supercar,” said General Motors President Mark Reuss. “It builds on the distinctive design and groundbreaking dynamics introduced with the mid-engine Corvette and elevates them to deliver refined but uncompromising track capability with world-class performance.”
As racing and performance enthusiasts love naturally aspirated engines for their responsiveness and trackability, the small-block LT6 was a clean-sheet design with the goal to create a naturally aspirated powerplant the would exceed the power of any naturally aspirated production V8 engine ever made. To accomplish that goal, Chevy engineers turned to a flat-plane crankshaft design, which combined with the LT6’s short stroke enables the engine to redline at 8,600 RPM.
The LT6 also features forged aluminum pistons and forged titanium connecting rods for low mass and high strength, and a six-stage dry-sump oiling system. It also looks like no other Corvette engine before with an all-new active split-intake manifold with 87mm throttle bodies and distinctive Edge Red camshaft covers. A carbon fiber engine cover will be sold separately as an accessory.
A version of the LT6 has powered Corvette Racing’s C8.R racers since 2019 and the direct transfer of technology from racing to street has never been more evident than now with the cars sharing the chassis, similar engine architecture, and exterior proportions. In fact, the C8.R has been described as the Z06 hiding in plain sight.
The LT6 will be hand assembled by master engine builders at the Performance Build Center inside the Bowling Green Assembly Plant. Like the previous engine builds from the PBC, each engine features a plaque on the intake manifold with the signature of the engine builder who assembled it from start to finish.
With racing fused in its DNA, the Z06 was designed to exploit its track capabilities in all areas. Chevy engineers added another heat exchanger in the center of the front fascia to pull in additional cooling, just like the C8.R race cars for the engine, brakes, and transaxle. The wider rear fascia also allows for larger air intakes required for cooling the Z06. In fact, the Z06 takes in 50% more air for cooling than the C8 Stingray.
The wide body design gives the Z06 a wider stance that is 3.6 inches wider than the C8 Stingray. This allows for the use of wider tires and wheels, with the Z06 offering 20×10-inch front wheels with 275/30ZR20 tires and 21×13-inch rear wheels that are sized for 345/25ZR21 tires. Michelin Pilot Sport 4S tires are standard with the Sport Cup 2R tires available with the Z07 Performance Package.
Three levels of increasing aerodynamic support will be offered for the Z06. The standard Z06 features a front splitter and a unique rear spoiler, which includes an installable fixed wickerbill on the edges that provides 365 pounds of downforce at 186 mph. Also offered is the available carbon fiber aero package that adds a larger front splitter, front corner dive planes, and a pedestal-mounted rear wing and under body aero strakes for the maximum track capable downforce and maneuverability. With the carbon fiber aero pack, the 2023 Corvette Z06’s downforce is rated at 734 pounds at 186 mph. It’s the most downforce offered ever on a Corvette.
“Virtually every component that distinguishes the Z06 was developed to support or enhance its capability,” said Corvette Chief Engineer Tadge Juechter. “By leveraging the mid-engine architecture’s inherent advantages, we are able to achieve six percent more downforce than a seventh-gen ZR1 at eight percent lower drag.”
Responsibility for stopping the Z06 will once again fall to Brembo Brakes. The standard Z06 features Brembo’s 14-6 inch diameter front and 15-inch diameter rear rotors, and unlike the Stingray which has four-piston front calipers, the Z06 will be utilizing a six-piston front calipers. The Z07 Performance Package allows for even greater stopping power with carbon ceramic rotors that include 15.7-inch diameter front rotors and 15-4 inch diameter rear rotors. The carbon ceramic brakes are a free-flow option that can be added to the standard Z06 without having to order the Z07 Performance Package.
The Z07 Performance package features include:
  • Carbon Fiber aero package (larger front splitter and dive planes, rear wing, and underbody strakes)
  • Unique FE7 Suspension with specific Magnetic Ride Control 4.0 calibrations
  • Michelin Sport Cup 2 R ZP tires developed specifically for the Z06
  • Available Carbon Fiber wheels that deliver a 41-pound weight reduction in unsprung mass
  • Brembo Carbon Ceramic brake system
The 2023 Corvette Z06 retains the SLA-type double wishbone front and rear suspension that was first featured on the C8 Corvette Stingray, but it has been uniquely tuned for its higher performance capabilities. Magnetic Ride Control 4.0 comes standard on the Z06 with drivers being able to adjust the suspension from touring comfort to maximizing track performance with the Driver Mode selector.
Like the Stingray, the Z06 can be tailored to the driving environment which includes Active Handling, Traction Control, Performance Traction Management, and more. The 8-speed automatic dual-clutch transmission has also been customized with a shorter 5.56 final drive ratio for enhancing the Z06’s acceleration capabilities. The Corvette Z06 is able to sprint from 0-60 mph in 2.6 seconds!
On the skid pad, the Corvette Z06 with the Z07 Performance Package is capable of 1.22 g of road hugging grip. The Z06 is so stiff that its track-capable versions are offered on both the Coupe and Convertible with no difference in the suspension calibrations.
Also unique to the Z06 among Corvettes is the exhaust note. The LT6 includes a “four-into-two-into-one” stainless-steel headers and centered “floating” exhaust bezels which are designed to maximize the precise tuning and sound of the exhaust note. Chevy engineers customized and tuned the sound of the engine and exhaust note for two years to find the perfect note for the new Z06. Customers will be able to choose between black or chrome tips.
The 2023 Corvette Z06’s performance and good looks are also matched by the quality of materials used in the cabin. New for the Z06 is an available carbon fiber wrapped steering wheels, shift paddles, and a new level 2 carbon fiber interior package. A new stealth aluminum trim option takes all the bright aluminum interior trim that includes the speaker and door bezels and makes them darker. Buyers can also take advantage of a new full-trimmed interior in Adrenaline Red that includes red carpet as well.
The Z06 also has the most personalization options available when selecting the choice of wheels, colors, and trim items. Customers will be able to choose between:
  • Twelve available exterior colors
  • Seven available wheel packages include five finishes on the standard forged aluminum wheels and available carbon fiber wheels
  • Seven interior colors with the ability to expand it to thousands of combinations
  • Three seat choices and six seatbelt colors
  • Two interior carbon fiber trim packages, plus a new Stealth Aluminum trim option
  • Sexy available brake caliper colors
Chevrolet will offer pricing information for the new 2023 Corvette Z06 at a future date. The Z06 will begin production in the summer of 2022, and it will be offered in Left and Right-hand Drive configurations.
Weight : 3430 lb dry
Downforce: 734 lb at 186 mph "We are able to achieve six percent more downforce than a seventh-gen ZR1 at eight percent lower drag.”
final drive : 5.56
Chevy on 10/26/21 unveiled the track-focused model of its mid-engine Corvette supercar, the C8 Z06.
Sporting the most powerful, normally-aspirated engine ever made, the Z06’s bespoke, 5.5-liter, dual-overhead-cam V-8 LT6) boasts a gain of 670 horsepower to 175 more than the standard, mid-engine Corvette Stingray, and 20 more than the last-gen Z06 and its supercharged V-8 LT4 engine.
The Z06 achieves its outrageous output using a free-spinning, flat-plane crank and 8,600-rpm redline technology usually associated with Ferrari supercars costing three times as much.
The spine-tingling shriek of the Z06 will be familiar to race car fans who have heard the engine propel the Corvette C8.R to seven wins and an IMSA sports car championship since its introduction in 2020.
"It's been hiding in plain sight. (We were) developing the heart of the beast," smiled Corvette Executive Chief Engineer Tadge Juechter as we circled a menacing, pumpkin-colored Z06 under GM’s Warren design center dome a week before Halloween.
To realize the full potential of the ferocious LT6 engine, Juechter and his guys had to make significant upgrades to the nimble Corvette C8,
which at $62,195 has sold like hotcakes with 495 horsepower and European-supercar good looks.
Stingrays are trading at some dealerships at $30,000-plus above sticker price.
Though pricing for the 2023 Z06 won’t be announced until closer to its summer 2022 release, expect it to start around $20,000 over a Z51 sticker which will be equipped with the must-have Z07 handling package
A huge, carbon-fiber rear wing juts from the rear chassis like a scorpion’s tail, putting over 730 pounds of down force. Fang-like dive planes pepper the face below the Corvette familiar, brooding headlights. Contrary to past Z06 upgrades, the ‘23 model shares only hood, hatchback, doors, and roof with the base Stingray.
Two features instantly distinguish the Z06 from the standard model.
The first: larger side intakes, shaped appropriately like a stingray’s tale.
“Performance aspirations force the car to look different,” said Juechter. “(It’s) enabled by the tires. That width drives the rear quarter panel out and makes the duct opening bigger, and the engine needs that.”
To harness the power of the LT6 mill, Michelin PS4 tires have been widened 1.3 inches over the already fat, 12-inch standard tire.
Softer compound Michelin Cup 2s are also available. The big rubber forced a 3-inch widening of the rear bodywork.
The second signature feature is the center-mounted quad tailpipes out back (the base V-8 splits its quad pipes into pairs on either corner of the rear diffuser). Juechter said the change was necessary in part to better channel the high-revving V-8's sound not just for exterior presence, but also for the enjoyment of the driver riding in the forward cabin.
The new, bigger fascia is more pronounced, holds three heat exchangers (the standard Stingray has two) to cool the temps within.
“We start with the Stingray, then amp everything up.
This is the first time we’ve done a full perimeter” on a Z06, said Juechter, referring to the exterior bodywork. “This enables us to do a better job on aerodynamics, package more coolers. We wanted this to be extremely capable on track.”
Juechter said Chevy’s new track weapon significantly outruns the previous-gen Z06 and can go wheel-to-wheel with the winged, $122k, 755-horse ZR1 C7 uber-'Vette.
With the Z07 package, the Z06 makes 734 pounds of downforce at 186 mph, the most of any Corvette ever.
On the skid pad, Juechter says the Z06 will pull a neck-straining 1.22 g-loads compared to ZR1’s 1.2.
At 186 mph, it boasts 6% more down force, 8% less drag.
The standard Stingray’s high-tech interior already shames most European exotics, and the Z06 doesn’t fiddle with the formula.
The instrument displays are digital, configurable. Wireless Apple CarPlay and Android Auto are standard, so you can find the nearest racetrack.
The square steering wheel is festooned with useful buttons, including Z-mode, so you can instantly transform the car from interstate comfort to nuclear weapon should any muscle-car peer dare to challenge.
In keeping with its expected $20k premium over the Z51 based C8, Z06 has turned up the volume on materials.
The steering wheel can be trimmed in carbon fiber, as can the entire center console.
All this performance is still available in both coupe & removable hard-top convertible configurations, trunk and front trunk storage are uncompromised.
The coupe version allow you to gaze into the engine chamber at the 5.5-liter engine.
Not only does its high-pitched note sound like a Ferrari, its output is well north of the $300k Ferrari 458 Special V-8's 597 horsepower.
More comparisons?
The production LT6 engine has 170 more horsepower than the C8.R race engine due to Balance of Performance restraints placed on the race car to keep it from running away from class competitors.
“We have a lot more power than the race car,” laughed Juechter, who also points to the sophisticated, standard, magnetic dampers on the Z06 also prohibited in racing.
The race car and production Corvette C8 were developed in parallel, ensuring a direct technology transfer from track to street.
The C8.R shined in its first year of IMSA sports car competition, capturing six victories and winning the GT manufacturer's title.
“The new Corvette Z06 defines the American supercar,” said GM President Mark Reuss, himself a race-licensed driver.
“It builds on the groundbreaking dynamics introduced with the mid-engine Corvette and elevates them, too.”
It will be built in Bowling Green, Kentucky, in left-and-right-hand drive configurations, the latter for overseas markets.
“Ex-Corvette racer Oliver Gavin has been doing development work at the Nürburgring,” said Juechter, referring to Germany’s racetrack.
“(We want) to make sure the car is competent on track and on the Autobahn, which is why we go there. We want to sell this car in Europe.”zO6.jpgzO66.jpgzO65.jpgzO63.jpgzO62.jpgzO64.jpg
That's very progressive of Corvette. :ROFLMAO:
I also want to know what the MPG is, the CO2 emissions, and how many suitcases will fit in it? :unsure::ROFLMAO:
I guess the GM guy who wrote that was feeling very hot when he is around a C8 ZO6 :)
There is no loss to the rear and front storage space and GM even sells as an option, Corvette travel luggage
As to mileage, that depends on if the driver is a waxer or a racer !
Yeah, I was just joking about that - most car reviews nowadays just seem to focus on practicality, how "green" the car is, and how cheap it is to run. So its nice and refreshing that Corvette haven't stated any of those details - because to be fair, if you care about those kind of details then a Corvette isn't the car for you :ROFLMAO:
Out of interest, what term do you use for a driver that is in-between a "waxer" and a "racer"? (maybe a "wacer", or a "raxer"? LOL) I ask as that'd probably be me, I like fast-ish / fun cars, but I don't drive them amazingly fast due to various medical reasons that I feel we don't need to go into here. I do like the loud pedal though.
