As i am being held back on the engine removal for a couple weeks i mite aswell get the parts together for it.
At the minute i am not sure on whats in there. So mite aswell start from scratch. Its a 5.7 GM Goodwrench crate engine. If i could work out wat the cam is in it etc i would as that would help out but i have been unable to get any help on how to get the specs of the cam.
It has a Quadrajet carb so a good start i believe being a 4 Barrel. Next is a Cam. i be;ieve a Comp 252 Cam. Now which one as i see theer are a good amount of 252 cams to choose from.
And the Inlet Manifold is standard i think along with the heads.
It will be used on the road, maybe the odd track day so i ahve been told a 252 cam is the way to go. Any suggest on what to go for without blowing thousands on it for now.
BTW it was meant to have around 300bhp, i was planning on refitting the heads as that is all that was removed for an upgrade by previous owner. I went to replace the ehads and one head bolt has stripped the block so it has to come out now anyway. And while its out ill upgrade it now.
Waynio
Waynio
