Hi again, The previous owner of my 72 says he didnt fit a choke, it is a 350 with street cam and 10-1 compression built on a 73 4bolt block and 2.02 double hump heads.
carb is a 650 double pumper. I seem to be flooding it as very lumpy and rich smelling when cold and takes a while to run smoothly.it may start a couple of times then stall but Once warm it runs sweetly and idles smoothly. I was told to crank for 10 seconds to build oil pressure then give a couple of pumps on the throttle if it hadnt run for over a week Or just pump once if had been run More recently.
any advice as to the best procedure to start appreciated. It has a 160 deg thermostat fitted.
