Hi MM john, When my 72 arrived after a long journey from the states and a period of pos 2 months without starting I checked all fluids and levels and then pulled the coil lead from the centre of dizzy cap and wound her over for several short periods to get things moving without starting. Oil pressure came up to 70 so then plugged the lead back in pumped the throttle a few times and she fired up. It took me a while to find the starting procedure. I was surprised at how much gas i need to pump into the carb to get her running smoothly. I would think next winter to not only get a battery conditioner/ trickle charger but make sure you start her up every 2/3 weeks. You get a fair bit of condensation from the exhausts, best to pick a dry day and actually run it up the tosd to get it warmed up and to get the brakes and steering Moving .
this should avoid having to re bleed the brake system slso, vehicles dont like being stood for long periods. Good luck , hope you enjoy yr first trips back on the rosd
