Hardrinseron
Hi folks,
My recommissioned 1978 C3 has a lot of slop in the steering box. The rag joint is new so its not that. I've tried adjusting the screw on the pitman shaft but it made zero difference. I'm now wondering if i should try and adjust the worm shaft or just ditch it and get a new box. Can anyone tell me is it possible to adjust the worm shaft without removing the box? is it just a case of loosening the lock nut and tighteing the bearing nut inside, then tightening the lock nut again?
thanks!
thanks!
