Tyres
EddyEdden
Hi all, Does anyone know where I can purchase Nitto Invo tyres / tires in the UK or know of any US company that ships to UK. I am looking for the following sizes: 295/35/ZR18 99W and 345/30/ZR19 105Y. Any help appreciated. Thank you.
EddyEdden
Thanks Rosco, Met with them at Rally of the Giants last weekend. Still waiting to hear back from them.
Thank you for your advice though.
EddyEdden
Thanks Team ZR-1 though always comes up as TOYO, I understand TOYO own NITTO but don't appear to advertise them.
Thanks also Chuffer for that info - have you seen yourself on utube leaving Rally of the Giants?
You need to select by tire type/size and not by vehicle and shows
We found 3 tires that will fit your size​
REQUESTED FRONT TIRE SIZE: 295/35R18
REQUESTED REAR TIRE SIZE: 345/30R19
Invo​
Luxury Sport Ultra High Performance​
High-performance cars need high-performance tires, because nothing should detract from feeling the roar of the engine.
View Details Invo
Find a Store Invo
Performance Ratings​
  • Dry Performance rating is a 4 out of 5
  • Wet Performance rating is a 4 out of 5
    Quietness rating is a 5 out of 5
  • Ride Comfort rating is a 5 out of 5
Invo Tire Specifications
Weight (lbs.)
Load (lbs.) @ Press. (PSI)
Maximum
Approved Rim Width Range
Min-(Measuring)-Max (in)
Overall Dia. (In.) Overall Width (In.)
Inflated Dimensions
Wheel Diameter Tire
Size
Stock Number Tread Depth
(1/32 in)
18 295/35ZR18 99W 203330 10
26.02 11.54
10.0-(10.5)-11.5
1709 @ 51
31.85
19 345/30ZR19 105Y 203300 10
27.17 13.35
11.5-(12.0)-12.5
2039 @ 51
37.27
Technical specs are subject to change without notice.
*Indicates Extra Load (XL)
NT05
Max Performance​
Put your car’s power to the pavement without compromises, just pure, responsive handling perfect for the track.
View Details NT05
Find a Store NT05
  • Dry Performance rating is a 5 out of 5
  • Wet Performance rating is a 3 out of 5
  • Quietness rating is a 2.5 out of 5
  • Ride Comfort rating is a 2.5 out of 5
NT555RII​
D.O.T.-Compliant Competition Drag Radial​
The high-grip compound in Nitto’s most advanced drag radial makes short work of the competition, and the drive home.
View Details NT555RII
Find a Store NT555RII
  • Wet Performance rating is a 2.5 out of 5
  • Quietness rating is a 2 out of 5
  • Ride Comfort rating is a 3 out of 5
NT555RII Tire Specifications
Weight (lbs.)
Maximum
Inflated Dimensions
Wheel Diameter Tire
Size
(1/32 in)
19 345/30R19 105W 108730 6.3
27.2 13.78
11.5-(12.0)-12.5
2039 @ 51
32.85
EddyEdden
Thanks again Team ZR-1, yes looking at type and size and not vehicle.
NITTO INVO's already on the car and want to stay with them. Unfortunately the link you have given keeps coming up with TOYO not sure why.
Car highly modified (not by me) runs 650BHP and 650torque and very well sorted and spec'd. including tyres, hence wanting the same again.
Nitto Invo - an interesting and unusual tread pattern - how have you found these? - as compared with other tyres? - I was considering track day or drag radials frot he rear of mine to try and get some traction - only seen American reviews on Invo's so far.
As what I posted above for the 3 Nito models with your tire sizes, I do not see TOYO
those 3 models clearly are Nito '
On each model I posted above, click on View details for more info
also if clicking on Finding a Store for each you could put in a UK address to see what dealer there is or in another country or
Go here and contact them to find where you can get these tires outside the USA
Your running wide tires front/rear
I use 275/35 fronts and 335/30 on rears 18-inch rims front/rear
EddyEdden
Thanks Rosco, not used other tyres only years ago on a C3 but very happy with them.
Thanks again Team ZR-1 I will have another try. They don't come out well on noise rating but exhaust sound drowns out any tire noise.
EddyEdden
Tried latest links and previous ones again but still comes up with TOYO. No mention of NITTO. I have messaged TOYO to ask why and if they are able to send me a link or explain why.
Haven`t seen that Eddy , thanks for the tip off I will have a look . (y)
