Udders
Fenman
Hi all, after looking at some American corvette sites I came across the term rainwater and realised the c5 has these strange drainage items.7933B19C53D3-C915-4D99-94CE-36F6A8C11A23.jpegI’vi was amazed how much crap was in them. Any thoughts on them? They seem to be overkill for a drainage device and are ideal for holding leafy mush that can cause blockages.
oelarse
I agree to that .
You have three udders on driver side (left side)
7989
And a longer one on passenger side rear of the battery . This one can destroy your body control module if it get blocked and result in a wet passenger footwell & a dead bcm
7990
dskopp
I have A 1998. One udder on passenger side and one on drivers side. They collect the water as it comes off the windscreen!!
silver50
Busy user
They do seem a poor design because can block up so easily and aren't obvious or particularly easy to remove.
If anyone has any spare ones, particularly the long passengers side one let me know. I had to ditch my one and have improvised at the moment by sealing a small plastic funnel on under the scuttle panel with a hose fed down to the sill
Eurovettes
hear is a simple way to modify them - you only have to do this once - there are 4 udders per c5
