C8 Owners question why they should buy the more costly ESP Dexos engine oil, where the Europe Mobil 1 is much cheaper in cost.
An answer to "why" the ESP Dexos II from the Mobil 1 rep is recommended (for the Corvette Small Block engines with dry sump systems),
was that the Dexos brand "has better aeration of the oil in a dry sump system" than does the European Formula Mobil 1.
Chevrolet has recommended the Dexos brand since the C7 which also was a dry sump engine.
As far as availability and pricing, searching the internet will get you lots of retail sellers with a wide variety of pricing!
It seems that Exon Mobil is doing special oils for GM and Corvette in particular.
The recommendation for the LT6 Z06 engine is a 5W-50 (with a new ESP Dexos6 formulation).
