My '68 big block C3 has always been 'on the edge' relating to overheating in certain summer conditions. Nothing new - anyone with a C2 or C3 Vette will know the scenario of continually keeping an eye on the temperature gauge whilst you gradually 'cook' in summer temperatures. OK so I replaced the water pump some years ago with a high performance Weiand unit. Added-in a new DeWitt OEM pattern aluminium radiator. I've made sure that all rubber seals around the radiator mounting are in place. The is additional stuff making sure the fan shroud is sealed to the front end. I've dropped the front license plate down 6 inches to 'unmask' air flow. Bottom line is that ALL cooling air that comes through the front end ONLY passed through the radiator. And it works - I may still be 'spit roasted' in heavy traffic but the 'sweet spot' cruising in 33 temperaturea is 65 mph at 185 degrees. Yeah, in heavy traffic, major hold-ups etc it'll hit 190/195 but thats about it. TBH winter is more of an issue in keeping it over 150. Last few days in the 30-32 temperature its been running at 200-210. Still running OK but IMHO 'on the edge' on boiling over. Which is exactly what happened - guage went off the scale and off it went.
The one thing I had never replaced was the viscous fan coupling. Obviously the original item and whilst the fan bearing seemed fine you'll see in the images a small amount of greasy crud around it which could be indicitive of the silicon fluid leaking. A proper test is when the engine is fully warmed up (and fan engaged) to stop the engine and attempt to rotate the fan blades. There should be significant resistance to rotating...........mine, same as when cold.
Anyway I sourced a new one and we're now back to 175 - 185 summer running urban temperatures once more.........seemingly.
