I have mentioned in the past that E-Ray owners found they could NOT start the eFWD in stealth mode only ( which is gas engine off) when weather temps are below 50 F degrees
My inside GM source who spent the last 2 years working on the design and road testing replied to me on this and stated
As to the 50 degree and below E-Ray not allowing Stealth mode
It is only true for Stealth mode, which operates in eFWD for up to 45mph/4 miles.
The reason is the E-Ray shares a carryover Stingray HVAC system, which does not operate when in EV only mode.
Lower than 50deg has risk of flash fog/frozen windshield conditions that are unsafe, and we have no functional way of solving it,
so there is a temperature threshold.
The actual eAWD system is absolutely functional below 50deg and operates well in extreme temperatures as long not in Stealth only mode, as we put it through the paces in Michigan winters for several years and even Colorado!
The E-Ray is so fast, a total riot to drive. Hope you get to drive one soon, it was an awesome project to work on.
