phn
Hi there, I was trying to figure out where to attach a permanent CTEK trickle charger connection to my C5.
The battery is diffrent to any I have seen before with the terminals on the side of the battery rather than on the top.
There is also a remote positive terminal under a cover next to the fuse box (see attached picture)
Should I attach the permanent CTEK connection to the terminals on the side of the battery (I am not sure if there is enough space for the spade to fit there as there is no exposed thread) or should it be fitted to the remote positive terminal (but then I couldnt find a good earth anywhere near the battery where the negative spade could attach to?)
Appreciate any knowledge anyone has on this - if someone has a permanent CTEK lead on their car how did you fit it?
Thanks as always!
Thanks as always!
