Afternoon
I've been looking around at some C5s and would appreciate any insight into a couple of repairs that I'd look to make on one of the options I'm keen on.
The first is an ac fault, with the following symptoms (from memory so I may have to update if I've got anything incorrect). The fan system blows hot but not cold. No HVAC codes were stored and when I pressed the AC button the light came on for a few seconds but then went out again. I suspect that the ac hasn't been used much recently and realise that there could be many possibilities (low pressure?) but does anyone know of any obvious things to try?
The second seems to be an oil pressure sensor as the analogue gauge sits at maximum and the digital gauge reads 130 psi. It looks like this is the symptom of a faulty sensor, but is there anything else to look out for to make sure that everything (apart from the sensor) is healthy?
Best regards,
Bill
Best regards,
Bill
