Using a D/C volt meter
With car off what is the reported voltage read ?
With the engine running at idle, what does the voltage report ?
Reving the engine up, what does it then report ?
At idle, measure voltage at the generator output post, what it reads ?
And then the other end of that wire connected to fuse block read ?
If no output seen and that wire is good than maybe a fuse link has blown
Should see voltage at battery posts at idle around 14 volts
Check the belt is not loose and pulley of generator not spinning well
