Evening All! It's been a week of mixed fortunes as far as the rebuild is concerned. I'm still tinkering with the vacuum system - something still isn't quite right. A set of golf tees that I can't remember why I have - I don't play golf - are very effective at blocking off individual sections of the circuit to help isolate problems. Hopefully I can get this sorted soon.
Not being someone to do one thing at a time I decided to rebuild the heater box - it's been taking up a fair bit of floor space and once rebuilt can be boxed up and stored somewhere until next required. The heater core is scrap, something I had suspected as it has been bypassed by the previous owner. A new one has been ordered but I have put the old one back in until that arrives to keep everything in order.
The heater cable (from the control unit to the heater box) has also seized and unfortunately snapped (due to corrosion) when I tried to free it up. I will try and repair this if possible otherwise a new one will be required. Amazingly, the vacuum actuator still works. The mechanism operates a lot more smoothly now that it has been cleaned and lubricated.
The rubber valves/vanes were treated with a rubber lubricant made for window seals which hopefully will keep them supple for another few years - they certainly look and feel a lot better for it.
The control unit has been cleaned, lubricated and the electrical contacts have been polished. I will paint the lens surround black sometime next week if the weather warms up a bit. A new lens is probably required but stripping it may well turn out to be a one way street as it's quite complicated and the design seems to rely on bending a metal tab to get the lens out - I never seem to get on well with those and they are quite expensive if the tab snaps off. It feels much better with a little grease on the moving parts so I will probably leave it as it is.
The main problem for this week was the gearbox. Removal of the tail shaft to replace the bush and seal requires a small tapered pin to be knocked out of the reverse selector lever turret. Apparently these are notoriously difficult to remove and this one is no exception. I tried everything but decided to bale out before I broke something or the pin became unrecognisable - I think it will require drilling out and needs a precision I don't think I can do at home. The tail shaft is very worn on the outside (hence the desire to inspect and replace the bushing) although there is no play in the spline. This doesn't seem to make sense to me and may indicate some other issue. Anyhow I have decided that this diagnosis and repair needs to be done by someone who knows what they are doing so it will taken to a local professional in the New Year.
Lastly, I removed the drivers seat reinforcement plate from the underside of the floor pan by drilling out the 4 rivets that hold it in place. When I removed the seat one bolt had already corroded through and one had to be sawn off (see pics) - a common situation with my car. It was going to be a lot easier to remove these broken bolts on the bench especially as the remaining stubs had to be filed down to get purchase, heated, squirted with Plus Gas etc. to get them out. Which they did - after a struggle. This plate is now having the rust removed - not a lot of rust actually and it's in remarkably good shape - and will be painted prior to refitting.
Over the next week I am going to try and plan out the next part of the rebuild and sequence the work a little better. One of the things I had underestimated was the amount of space necessary to do a build like this so I need to shuffle things around a bit so that I can keep going...
