C3 Lockdown Project
Vetman
I have slogged away making the other front air-dam bolt-on, and ensuring that they fit the same both sides. The bolt fixings are all existing without the need for additional drill holes. How do Pace Car corners attach?
These corners supplement the deeper rubber air-dam.
Photos attached.
Vetman
Nearly finished my Lockdown Project. Still have to connect rear camera dash cam and radio antenna. Also some badges. Reasonable colour match using a semi Matt spray can. Other paint mods may follow.
Some photos.
Superb and totally unique. The rear hinges like a hatchback presumably? Have you got any pics of how you’ve done that?
Vetman
Lift the tail end and it pivots forward from this position so that front tabs locate beneath the rear window arch and side tabs keep it central. The tail then lowers to lock to the back of the luggage frame. The racing pins provide a final lock down but air pressure on the rear wing surfaces should also keep it down.
The usual up position uses the front tabs leaning against the rear glass and a strict to hold the tail up for petrol cap access.
Earlier photos attached.
Vetman
Too kind.
The lockdown project is just about done. I have adorned the rear piece. No point in being subtle, after all it is American.
