I spotted the Scat crankshaft box on another post! Is that forged? I like the look of the light weight flywheel too. Are there restrictions on what you can do with the engine spec?
Yes forged crank, standard stroke so with the overbore that’s allowed it’ll be a 355cui.
Flywheel is a light one. Couldn’t find evidence of a small block using a twin plate clutch in period, although the big blocks did, so went with a single plate. Plus they’re not as sensitive to being cooked when manoeuvring as the little sintered ones.
Engine wise needs to be period correct and tie in with the homologation so iron head and block.
I dropped the crank and stuff off to be balanced today.
Front end ironwork on
Back to playing with bodywork.
