Remove: | ||||||||
From Front | ||||||||
Mechanical | ||||||||
Front bumper and frame reinforcements | ||||||||
Unbolt nose support from frame (will stay with body) ?? | ||||||||
throttle cable (at carb) | ||||||||
steering rag joint also remove column?? | column removed | |||||||
brake lines (at master cylinder) | ||||||||
Radiator | ||||||||
Radiator core support bolts, lower only - Remove | ||||||||
A-Frame dust covers - Remove from under A-arm?? | ||||||||
fuel lines | ||||||||
Electrical | ||||||||
Starter wires | 1 large, 1 small (on connection nearest engine block) | |||||||
Ground straps (more than one place) | one on trans next to starter motor | |||||||
oil pressure sensor (below distributor) | ||||||||
Alternator wires | ||||||||
small body earth strap at driver's side no.1 body mount | ||||||||
horn | ||||||||
Air con compressor clutch cable and earth | ||||||||
water pump sensor (driver's side engine head) | ||||||||
Speedo cable | ||||||||
spark plug leads so they don't get caught | ||||||||
distributor (2 plugs) | ||||||||
body mount bolts | ||||||||
brake balance switch (under master cylinder) | ||||||||
Vacuum lines | ||||||||
brake booster vacuum hose (intake manifold) | ||||||||
headlight vacuum reservoir (3 pipes) | ||||||||
carb vacuum connection | ||||||||
fuel canister hose (above driver's side splash shield) could be up to 3 hoses | ||||||||
Water hoses | ||||||||
Heater and A/C hoses from motor | ||||||||
water pump outlet to AC unit | ||||||||
AC unit return to intake manifold | ||||||||
From Center | ||||||||
Parking brake cable and brackets from under seat area | there is a spring that goes from the adjustment rod to the crossmember | |||||||
Shifter cable | ||||||||
Battery ground strap from frame | ||||||||
Rocker moldings | ||||||||
Seat belt anchors, left, right and center - remove?? | ||||||||
From Rear | ||||||||
The rear bumper | ||||||||
aerial earth/rear chassis earth (driver's side rear corner) | ||||||||
Gas tank ground and sending unit wire |
