Good work. Also handy for me seeing the steering box, rag joint and steering column all clearly exposed. I want to replace my rag joint and I'm trying to work the best way to do it - undo and pull steering column into cockpit, or undo and move steering box out of the way. Moving the steering column and wheel seems risky as chance of damaging cables and other stuff attached / near the column. But moving the steering box might be a pain.
1968. I too hope I have the right one for mine too - came from Rock Auto and it was listed for my car, so fingers crossed.Steering box I reckon. What year is your car, I struggled to identify the right rag joint fir mine.
I pulled the steering column - it was pretty fiddly getting it back again. Swinging the steering box clear might be more straightforward.Good work. Also handy for me seeing the steering box, rag joint and steering column all clearly exposed. I want to replace my rag joint and I'm trying to work the best way to do it - undo and pull steering column into cockpit, or undo and move steering box out of the way. Moving the steering column and wheel seems risky as chance of damaging cables and other stuff attached / near the column. But moving the steering box might be a pain.
Have you described the engine in any earlier posts? I may have missed it.
Maybe a silly question, but why didn't you finish doing the sanding before you fitted the engine?
Looks terrific - really admire the finish you have managed to get on the frame and chassis components.
How long does it take for each grade of paper?
You certainly know how to enjoy yourself
