Yes it doesn't seem much, that's why Andy used a double sided tape. I could put plenty across the bottom, but your screen doesn't have such a deep blacked out area at the bottom as mine. Good luck with it anyway.I’m surprised that there’s only about 1/4” of the screen that will actually be glued in all the way round.
My blue Corvette looks a bit like that at the moment - I removed the rear bumpers to make them shiny. Blimmin rusty old bolts though, had to cut one off. Also only appear to be held one with only 3 bolts per side - the fourth bolt in the lower "fang" parts both side (aka the bit next to the number plate) weren't fitted to mine. But then, the brackets that go down to those locations are also missing too. Hey hum, weight saving I guess as the bumpers were solid on with only 3 bolts.
Thanks for the pic. I saw on a technical diagram of the Vette that it should have a bar going down to mount that 4th bolt for the bumper. But the photo above demonstrates it much nicer than the diagram. The bumpers seem to stay on solidly with just two bolts - I drove it for a bit with only the two middle ones as it needed to go to the garage and I gave up getting the bolts off after getting the outside ones off (near the wheels) which were a PITA to get off. Prior to that it only had 3 bolts and I was completely unaware and it seemed solid. One day I might make it more factory like.... a trip to a fellow "CK" (Corvette Kingdom) might be in order..... but its low priority.
Apologies, these lights they are on both sides and are externally facing out through the lower rear valence. My first thought was reverse lights. I need to find my voltmeter and see if they get power etc. They have been disconnected since before I got the car, so there must have been a reason.I think the extra light is for the spare wheel.
