C4 ECM Error Codes By JR - Team ZR-1 Corvette Racers LLC | |
DTC | Circuit or Sensor |
11 | Malfunction Indicator Lamp Circuit - VIN P Only |
13 | Oxygen Sensor Circuit |
14 | Coolant Sensor Circuit (High) |
15 | Coolant Sensor Circuit (Low) |
16 | Ignition Problems (Used on 1992–1996 models only) |
18 | Injector Circuits - VIN P |
21 | Throttle Position Sensor (TPS) (High) |
22 | Throttle Position Sensor (TPS) (Low) |
23 | Intake Air Temperature (Low) |
24 | Vehicle Speed Sensor (VSS) |
25 | Intake Air Temperature (High) |
26 | Quad Driver Module Number 1 - VIN P |
27 | Quad Driver Module Number 2 - VIN P |
28 | Quad Driver Module Number 3 - VIN P |
29 | Secondary Air Injection Pump Circuit - VIN P |
31 | Camshaft Position Sensor - VIN J Only |
32 | Exhaust Gas Recirculation Circuit |
33 | Mass Air Flow Sensor Circuit (1985-1990) |
33 | Manifold Absolute Pressure High (1984 and LT-5) |
34 | Mass Air Flow Circuit (1985-1990) |
34 | Manifold Absolute Pressure Low (1984 and LT-5) |
35 | Idle Air Control Circuit (IAC) - VIN P |
35 | Manifold Absolute Pressure (MAP) - VIN J |
36 | Mass Air Flow Burn Off Circuit - VIN P |
36 | Electronic Ignition System Missing or Extra IC Signal - VIN J |
37 | Brake Switch Stuck On - VIN P |
38 | Brake Switch Stuck Off - VIN P |
41 | Cylinder Select Error Circuit (1985-1991 and LT-5) bad E-Prom |
41 | Ignition Control (IC) Circuit Open (1994-96) |
42 | Electronic Spark Timing Circuit (EST) IC Shorted - VIN P |
42 | Ignition Control (IC) Timing Circuit - VIN J |
43 | Knock Sensor Circuit |
44 | Bank 1 (Left Front) O2 Lean Exhaust Indicated |
45 | Bank 1 O2 Rich Exhaust Indicated |
46 | VATS Anti Theft Circuit Fault - VIN P |
47 | Knock Sensor Circuit or Module Missing - VIN P |
48 | Mass AirFlow (MAF) Sensor - VIN P |
50 | System Charging Voltage Low - VIN P |
51 | PROM/EEPROM Error |
52 | Oil Temperature Circuit (Low Temperature) |
53 | System Charging Voltage High |
54 | Fuel Pump Circuit (Low Voltage) |
55 | Engine Fuel Running Lean |
56 | Secondary Air Inlet Valve Actuator Vacuum - VIN J |
58 | Trannie Fluid Temp Circuit low |
59 | Trannie Fluid Temp Circuit High |
61 | Secondary Air Inlet Valve Actuator Valve - VIN J |
62 | Engine Oil Temperature Circuit (High Temperature) |
63 | Bank 2 Oxygen Sensor Circuit (Open) |
64 | Bank 2 Oxygen Sensor Circuit (Lean Exhaust) |
65 | Oxygen Sensor Circuit (Rich Exhaust) |
66 | Air Conditioner Pressure Open or Shorted |
66 | Valet Power Switch - VIN J |
67 | Air Conditioner Pressure Limit Exceeded |
68 | Air Conditioner Relay Fault |
69 | Air Conditioner Clutch Fault |
70 | A/C Clutch Relay Driver |
72 | Speed Sensor Loss or Gear Selector Switch Fault (Start Lockout) |
73 | Pressure Control Solenoid - PCM only Circuit |
74 | Traction Control System - Low |
75 | Trannie System Voltage Low |
77 | Primary Cooling Fan Relay Control |
78 | Secondary Cooling Fan Relay Control |
79 | Trannie Fluid Over Temp |
80 | Trannie Component Slipping |
81 | Trannie 2-3 Shift Solenoid |
82 | Trannie 1-2 Shift Solenoid |
84 | 3-2 Control Solenoid - Auto Trannie |
84 | 2-3 Gear Block out Relay - Manual Trannie |
85 | Trannie TCC Stuck On |
90 | Trannie TCC Solenoid |
91 | 1 to 4 Up shift Lamp - Manual |
97 | VSS Output Circuit (Speedo) |
