When key on, does the fuel gauge show the correct amount of gas in the 2 tanks ?
The PCM has two 80 pin wiring connectors, on the PCM it is labeled RED for one and BLUE for the other
Focus on pin 9 of the RED connector as that is the control wire to the fuel pump relay
IF that relay has 5 pins, then the relay socket of fuse panel is wired this way and see if 85 and 86 show 12 volts for the relays coil
PiN 30 would then go to pin 9 of red connector of PCM and pin 87 would be the 12 volts to the fuel pump
With the other problems you have had, it maybe the time to get to the PCM,
Look for acid damage from battery leaking down to PCM or water damage and all that wiring and also the ground there
May have to take off both wiring connectors and closely look at both the male and female pins for damage or dirty
and spray electronics cleaner and make sure none of the pins have push backwards and not connecting
Pin | Wire Color | Function RED Connector |
1 | BLK/WHT | PCM Ground (Automatic Transmission Only) |
2 | BRN | TCC Control Solenoid (Automatic Transmission Only) |
3 | -- | Not Used |
4 | PPL | AIR Solenoid Control |
5 | TAN/BLK | Torque Delivered |
6 | RED/BLK | Transmission Fluid Pressure Control Solenoid High (Automatic Transmission Only) |
7 | -- | Not Used |
8 | LT BLU/WHT | Transmission Fluid Pressure Control Solenoid Low (Automatic Transmission Only) |
9 | DK GRN/WHT | Fuel Pump Relay Control |
10 | WHT | Engine Speed (Tach) Output Signal |
11 - 13 | -- | Not Used |
14 | RED/BLK | A/C Refrigerant Pressure Sensor Signal |
15 | RED | Alternator L Terminal |
16 | -- | Not Used |
17 | DK GRN/WHT | A/C Request Signal (C60 only) |
18 | DK GRN | A/C Status Signal |
19 | -- | Not Used |
20 | PPL | Vehicle Speed Sensor (VSS) Reference Low |
21 | YEL | Vehicle Speed Sensor (VSS) Signal |
22-24 | -- | Not Used |
25 | TAN | IAT Sensor Signal |
26 | PPL | Ignition Control 1 |
27 | RED | Ignition Control 7 |
28 | LT BLU/WHT | Ignition Control 6 |
29 | DK GRN/WHT | Ignition Control 4 |
30 | -- | Not Used |
31 | YEL | MAF Sensor Signal |
32 | LT GRN | MAP Sensor Signal |
33 | DK BLU | Engine Cooling Fan Relay 2 and 3 Control |
34 | DK GRN/WHT | EVAP Canister Purge Valve Control |
35 | -- | Not Used |
36 | BRN | AIR Pump Relay Control |
37-38 | -- | Not Used |
39 | RED | Camshaft Position Sensor B+ Supply |
40 | BLK/WHT | PCM Ground |
41 | -- | Not Used |
42 | TAN/BLK | TCC Enable Circuit (Automatic Transmission Only) |
43 | DK GRN/WHT | A/C Clutch Relay Control |
44 | LT GRN | Reverse Inhibit Solenoid Control |
45 | WHT | EVAP Canister Vent Valve Control |
46 | BRN/WHT | Malfunction Indicator Lamp (MIL) Control |
47 | WHT or YEL/BLK | 1 to 4 Up-shift Lamp Control or Transmission Shift Solenoid B |
48 | LT GRN | Transmission Shift Solenoid A |
49 | -- | Not Used |
50 | DK GRN/WHT | Vehicle Speed Output Circuit |
51 | YEL/BLK | Transmission Temperature Sensor Signal |
52 | GRY | Alternator F Terminal |
53 | -- | Not Used |
54 | DK BLU | Fuel Level Sensor Signal |
55-56 | -- | Not Used |
57 | PPL | IAT Sensor Ground |
58 | TAN/WHT | Engine Oil Pressure Sensor Signal |
59 | -- | Not Used |
60 | BRN | Ignition Control Reference Low Bank 1 |
61 | BRN/WHT | Ignition Control Reference Low Bank 2 |
62 | GRY | PRND C Input Signal (Automatic Transmission Only) |
63 | PNK | Transmission Range Signal A (Automatic Transmission Only) |
64 | DK GRN | Fuel Tank Pressure Sensor Signal |
65 | -- | Not Used |
66 | PPL/WHT | Ignition Control 8 |
67 | RED/WHT | Ignition Control 2 |
68 | DK GRN | Ignition Control 5 |
69 | LT BLU | Ignition Control 3 |
70-72 | -- | Not Used |
73 | LT BLU | Fuel Level Sensor Signal (Secondary) |
74-80 | -- | Not Used |
