IF after trying to start multi times and no other DTCs trip then Yes, maybe the starter solenoid or loose wiring to it
Kinda a bitch but starter is on passenger side of rear of block
Maybe a burnt spot on solenoid and tapping on it maybe enough to get off that spot just as a test
and if engine starts your off to rebuild or replace it
Any time there are U comm DTCs someone on the Starbus yacking and not allowing other controllers to talk in the network
Having seats out will clearly cause the DTCs to return even if you clear DTCs
Still is a question if Security/VATs is playing a part and relay noise, again bad cell of battery cannot handle current load and have problems with loads on relays
Yes the LEDs replacing DRL can cause DTCs,
In any case as to the ground splice packs, and other main ground points a good idea to clean and make sure good tight connections as
the controllers in many cases control functions not by voltage but reference to ground
BTW, if auto tranny do not forget the park switch and if out of alignment engine no start
This forum does not allow large content in posts and there is a lot of DTCs for controllers
so go to my Tech Forum, see most of them but click on the link there and download all of them in a PDF file
C5 DTC Trouble Codes
Image of starter and solenoid
