Evening all, has anyone done the clutch cross shaft rebuild with the nylon bushes and felt seals? If so, can you remember the symptoms before you did it?
My cross shaft has had some play , i have s rebuild kit and new block and frame ball studs, until now i have just been keeping the shaft greased and all has been ok.
I noticed this week that the clutch pedal is quiet when the car is cold, but after a run when it is hot , the clutch pedal when pushed makes a dryish not exactly a squeak but a noise that sounds like something needs lubing. My brother felt the rod and linkages in various places and feels and hears it but cant pinpoint the exact location.
Could the clutch fork need a
dab of grease on the bellhousing stud I wonder or the block and frame Studs that the shaft mounts on. ?
Clutch all working properly , just noisy when hot. Any suggestions welcome,
Many thanks
Many thanks
