Andy sorry to hear of your loss, I am sure you miss him at the track side when you are doing your bit and yes of course he had a wealth of knowledge that you could tap into
I originally had the problem of unequal heights (I learned measure vertically from the wheel arch to the rim at the bottom of the wheel, delete the tyre wall) I could not dial out the issues via the back spring bolts
I was greener then than now but I am still green on most things
I swapped the front springs over from side to side to see if their was an issue - no
I went as far as rotating the rear spring - as expected no change
I took the Vette to a crash repair specialist and had it mounted on a chassis Jig with all the wheels off and had the chassis checked to find all the measurements were bang on correct
I then went for the NSR Trailing Arm and replaced it, just in case it was bent although it looked good - no issue there
As a matter of course I then replaced the OSR Trailing Arm to match the change to the other side
Some time later, not on the same quest I had a body off and it was found (I do not know the part here so I can not quite imagine it and consequently hope I am making sense) that the rail at the bottom of the body where it mounts to the chassis on the near side, just before the rear wheel was not correctly in place and was a fault from manufacture and it was that, that was causing an issue
The body off was completed, the body went back on, no body mount shims were used, the Vette was sitting square and good with all heights equal, but and a big BUT, the NSF wheel was far back in the wheel arch and looking at the shims there was no where to go to get any beneficial change in caster
So you start thinking out of the box; had I got my chassis back, if anything was amiss with the components, it pointed to the bottom wishbone, Had I got my bottom wishbone back, was this nearside wishbone bent but I could not see it - I changed the bottom wishbone - no difference - put the old one back
So I met the Shark on the stand at the NEC, "no issues I can do that, need the car for two to three weeks" - ten months later blanking my calls and emails I get my car - he had not got a clue - I could go on with the curdling tales of the Corvette Rogue, but never mind.
So everything new on the car, but the caster issue prevailed, I had an excellent recommendation of an outfit to go through my car and set it up correctly, they race prepped Porsches and had a lot of trophies under their belt, but I waited and waited as their time was full and in the end, they said if you really need someone good go to ........................... several week wait and then all sorted in a day, the issue just came out in the wash - but by the time I went there my car was fully prepared for the ultimate set up - everything was new anyway, I put in the adjustable Coil Overs from VBP they had to get the 550 Springs made at Van Steel to suit, the front shocks were single adjust - all the wheels were balanced two days before - that caused a jittery issue - I had the whole car spanner-ed - no issues - took it to my favourite place for another wheel balance every wheel was out by the same amount - badly calibrated effort in the first outfit
So I have got the Tee shirt, but now have a Vette that is chalk and cheese away from where it was and where many C2, C3 Vettes are - So many do not know what they are missing, but although it is good to have the right bits, they are useless without it being set up properly
Sorry for the rant
